What does “Home Z” do and why is it moving the belts on Maslow4? I would think it should only be moving the Z axis but it starts to unwind 2 of the belts. Pressing it caused the belts to become unwound and since there was no tension on them at the time get jammed.
What that button is supposed to do is to set the z-axis to a known height similar to how “Retract All” pulls the belts in and then we know that they are length zero. That button is supposed to lower the z-axis all the way down to the limit and then raise it back up to 28mm which we’ve picked as the normal starting position.
I will check to see if it is working right and fix it or disable it if it isn’t.
