What is the cord used to connect the computer to Maslow 4?
If you mean to run a full install (like if you are updating firmware to v1.0), it’s a USB cable with a USB-C connector at the Maslow end.
In using this USB cord can we skip the wifi usage? It seems to drop a lot, and I cannot use the computer to surf the web if I need to.
I have had good success turning off Connection monitoring in Preferences (hamburger menu top right, above the Settings button). Then if there’s an interruption, the Maslow keeps on keeping on. Wouldn’t do that until I’d successfully calibrated, and your mileage may vary.
