First step finish ! I work on it tomorrow now…
Just a question, it’s normal to have this length of belt out of the spool?
Or I can cut the excess when I finish calibration ?
Yes that’s pretty normal. Bar and company provided a generous amount of belt, so much that some people have had issues getting it all on the spool. The motor should be able to wind the belt onto the spool tighter that you can by hand, so it should be okay.
Yep. Best to let it wind itself up so you don’t risk any slippage from loose hand-winding.
At this point (when you go to mount it for the first time) I would just extend all and retract all before doing another extend all to put it on the anchors.
After it, I try to connect to my Maslow Wifi, I put the pswrd “12345678” all is connected but nothing more happend… I try to put 192.168.0.1 on chrome and Mozilla but nothing happen
Anyone have an idea?
If I remember correctly, the Maslow’s network is unprotected by default. You shouldn’t need a password. At least, I don’t remember needing one to connect a laptop for the first time, and I’ve connected 3 different laptops.
I’m suspecting my profile sync pulled the saved wifi network over to my other machines before I attempted to connect, which would explain why I don’t remember seeing it when I connected the machines, because I would have only done it once. Thanks for calling it out.
(I think it’s normal)
I go on chrome, I write 192.168.0.1 in the search bar but it’s loading always and always but nothing work
The maslow have Green fix light but nothing more (the fan is off, idk if he need to start when you turn on the m4)
How do you install “Full_Install.bat”?
I mean, if I can’t connect to my M4 how i can update the firmware? USB C?
EDIT: I found the “how to install.txt”
Sorry i’m not the best for it >< If possible I do something wrong but idk what…
I ran the “Full_Install.bat” and it’s working! Many thanks @bar
For information, my M4 make a motor noise all the time when it’s not working but after new install all noise are stopped and I can run 192.168.0.1 on chrome
If it can help someone
Today I did my first cut! I’m really happy, it’s working good
I just need new cutter bit, I test helicoidal bit but it’s not working really well, I wait new one i’ve ordered today, I hope it came tomorrow for new test
