Trying to build a Maslow from scratch and can’t find this info anywhere.
Thanks!
Thanks!
I saw a post from early on for the stock motor and I believe it to be 8mm.
@bar, can you confirm?
the stock main motors are 8mm shaft
Thanks everyone, that answers my question.
Going to be a bit tricky to source given that it’s for a #25 chain and therefore mixing metric and imperial. McMaster Carr only has sprockets with shaft diameters measured in inches.
search around here a little, I saw someone found #25 sprockets awhile back and fairly cheap.
I found the conversation.
Thanks! You clearly have a knack for remembering old threads on this forum
I also just came across this a few minutes ago:
https://www.phidgets.com/?tier=3&catid=43&pcid=36&prodid=784
We’ve all had the same questions at one point or another. This forum is
great, usually a search will bring the answer after a little digging.
Well you can’t beat that price, good find.
Could you drill/ream a sprocket with a 1/4" opening to 8mm?
