Where get the gears for tensioning?
Hello all!
I’ve ordered my Maslow, built the frame, and while I wait for shipping, I’m working out my chain tensioning system.
I haven’t finished all my pondering, but one thing that stymies me is that there are only two gears in the kit. Some of my solutions require 4 gears in total. Where does one get just the gear/sprockets for the tensioning part of the chain system? Maslow surplus is sold out of all the chain tensioning bits.
Thanks!
-M
There are two gears and two sheaves as shown in the picture in the thread above. Although I used clothesline pulleys from home depot
cloathline pulleys work very well for managing the slack (I think better than
the original sprockets and hooks)
you can see a picture of this at
Thanks for all the hints on clothesline pulleys!
Also, what is the “stock” chain length from the standard makermade kit?
-M
11ft
if you go to a longer top beam, you need the chain to be 6-12" longer than the
beam.
I did the layout a little differently to maintain the chain tension. I’ve had zero problems with the chain tension. The only problems I have had have been because I hadn’t put any chain lube on the chains themselves so a couple of pins were seizing up and throwing cuts off.
Alternate approach to chain pulley system
