I understand about limits, but if I know the bottom and dont go to high, i never hit my head and I dont need to know where the ceiling actually is. anyway, i tried to write it up step by step, i got some work to do on it but let me know where I made any mistakes and I would like to help with this, this took a bit to get to, as of writing this I got a successful sign finally.
Make sure the router is turned off before turning on the main switch if you have configured your machine that way.
Turn Maslow On
Connect to Maslow “maslow.local” or your preferred method that works
Select the Maslow Tab at the top of the page
Press the “Alarm” button to release the Alarm condition
Press Setup button
If this is the first time then press “Config” when the Setup dialog opens.
You will need a tape measure for this, one with metric may be helpful or to go from inches to mm you can multiply the inches by 25.4 to get mm.
Input your frame dimensions from anchor point to anchor point and the orientation of the unit.
Make a note of your frame dimensions (I made a plaque on my frame, but any way to remember will do)
“Vertical” is standing up so the top two belts hold the sled
“Horizontal” is if your sled is parallel with the ground
Press “Save”
Note - You can press outside the window to go back to the main screen in case you do not need to configure your machine again.
Now you begin the Maslow start procedure. (This will be performed every time you shut off the machine)
Note - If router bit is inserted in the machine and you have not calibrated it I would suggest moving the Z up a bit and removing the bit before calibration because we will still have to define the “Zero Z” point, this is not home, this is the absolute bottom of the Z travel)
- Release the Alarm
- Open the Setup screen
- “Retract All” (This pulls all the belts in so watch out if they can get caught on things)
- “Extend All” (This should put the sled in the middle of your 4 frame anchor points)
- If this is way off, or the belts are not extended long enough to attach the top
Two in the vertical orientation then the frame has possibly not been configured correctly so check that again that your dimensions are saved.
- Is there a bit in the router?
- (Yes) But it is clear of the spoil board from dragging, then you may go to the next step and decide whether or not to calibrate
- (No) or you will take it out now to set your “Zero Z” point
- Setting the “Zero Z” point is part of your setting up procedure, so here we go.
- With nothing in the router collet, bring your Z down until it bottoms out on the Z axis motors.
- Press the “Zero Z” button on the Setup interface
Note- This is not your zero starting point for your router, this is something different, there is another spot we want to start routing called “Home”, it will also need to be set, but more on that later.
Is this a calibrate session?
(Yes)f this is the first time you have put in your frame dimensions or maybe applied an update to the yaml file, then it is time for “Calibrate” - go ahead, it will move around now and pause for calculations periodically, it will take a little while
(No)If the calibration was performed and your just going to make another beautiful cut on your machine then you can “Apply Tension” - well lets get routin
Congratulations on a milestone - A successful calibration or just getting ready to route again. Just refer back to these to stay on the path.
- At this point there should have been a successful calibration and your “Zero Z” point has been saved. Next time you power up you can just follow the directions and get to this point a little faster.
- The machine is on the frame now - do we have a bit in the router?
- (Yes) then head to the next step
- (No), make sure the router is off and unplugged
(if you still have the setup screen up just click outside of it to close it)
- Press “Z” to bring the Z menu up
- Press on the number area to input a number (I like 10 to start out, if it is too high you have to start over setting your Z point again because it can come off the lead screws.) If you come off the lead screws go back to setting the “Zero Z” procedures.
- Press “Set”
- Press “Up” and the machine should move the router up (10mm in this example)
- Repeat this until you have enough room to install your router bit, the router button helper in the “Not Shop” on the Maslow website can be a nice tool to help with this procedure. This is where I shut off the maslow before I put my hands in to install the bit in case it goes rogue, this means we need to the belt dance again (not calibrate) but thats okay. Go back into the Setup screen and “Release Tension” to allow your belts to be removed, remove them from the anchor points and “Retract All” now or when you turn the machine on again and go to Setup.
(Note)The router bit should not extend below the sled at this point. (if you have shut off the machine and realized it is not up far enough you can turn it on and connect to it, release the alarm and move the Z up, again minding that it’s not too much so you don’t have to set the “Zero Z” again.
- Install your bit and tighten up the collet while keeping the shaft locked and follow your router’s instructions.
- Unlock the shaft and I like to turn the collet a little to know it is ready and everything is out of the way, including the locking tool or collet wrench.
(Note)I have realized since writing this up that having a hole in the spoil board where I can set my “Zero Z” is a bit helpful at this stage of the game. You can add this if it is helpful to your frame later.
(Note)You should be confident your router is installed correctly and that the bit is secured and your workpiece is also secure to the spoil board. Get help now if you are unsure on any of these.
Install some material to cut, knowing that our sled will need some support around the edges, so give a little if your using a little piece or add some helpers on the edges where it will need support.
Turn the Maslow back on again and follow the directions to get back to where we were. Belts all installed (Retract, Extend, Install Belts and then “Apply Tension” this time) This is the most normal routine to my knowledge after you have Calibrated and set your “Zero Z”
Bring your bit down using the “Z” menu, try using small amounts when it gets close so as to not lift the sled off the spoil board. (I get close and when I touch at 1mm movements, I back it off)
Load your .NC file with “Load File” and then wait for it to upload and then select it in the drop down box below the play/pause/stop buttons.
Put the sled where your home is in relation to your file at this time and press “Define Home” There is also the “Define Home” Selection in the Z Menu and does the same thing if you have set your XY Home and need to do the Z Home, otherwise you can set your Z when you get it in place, this will help to not scratch your material with the router bit.
Turn on the router and the vacuum and press play
