Wifi conection instead of usb
Is it possable to connect to connect with a wifi connection instead of a usb for the maslow?
Depending on your board, it is possible, but I’m not sure if it has been done or how it would be.
A work around that most use for WebControl connects the control board (via a short USB) a Raspberry Pi WebControl installed (search the forums here for RPi and you should find the instructions on how to do that). Then you can use a Web Browser with the IP Address of the Pi and Port 5000 (x.x.x.x:5000) and it will connect to the Pi over WiFi and can do all that is needed to cut. I do it this way using a Surface tablet and it works great. I know others that use their phone and at least one that uses a Fire tablet.
