probably stupid question as the controller accepts cad files
BUT here we go
We use Vetric.com software - will it work with the Maslow?
If it doesn’t work right out of the box, send us a gcode file and we will make it work
vetric is a software for 2d carving - does the electronics accept standard gcode?
i cant send the gcode as it would have to be for every file we create
Maslow does use standard gcode
The gcode standard is pretty loosely defined and every program has it’s own flavor (using , instead of . to denote decimals…etc) so if you run into any issues we could probably make the firmware compatible with every gcode file generated using a given piece of software by looking at just one example of it’s particular flavor of gcode
Yes it does. I use vetrics vcarve pro and I cut with Maslow and xcarve.
