I maybe doing this wrong, but I have everything setup finally except the Z-axis motor. When I try to install it, it is always in the way of the metal carriage that the router is connected to.
Looks like you have router base wrong side at top. Z axis screw should be bottom right side as if you were gonna have the z axis motor.
Just like in this picture:
Yep, turn the router body around and you should be fine.
Thanks, I didn’t put the sled together initially, I figured that was the case.
Just wanted to make sure! Thanks!
