Hello, I’ve finally managed to build and mount everything, including my z-axis, a little machining done to make a nice fine accuracy for the z.
I’m experiencing a calibration or controller ‘problem’, this is the scenario, and I’ve spent a day and a half going around in circles.
Scenario:
- Mega mounted on 'wall mounting 2x4 (4x2 locally ;-)), noting this is an older CCA although CCA does contain copper and chromium, it shouldn’t have any Extra Low Voltage, nor low Voltage conductivity issues (LV <= 1000V) e.g. It’s an insulator, just like wood.
- PWM module mounted on the Mega, L&R Motors on MP1,MP3 with Z on MP2, e.g. Z and LHS motor sharing the same PWM.
Calibration observation:
- Calibrated ok, until the final ‘chain length’ where it wanted the chain feed mounted ‘upside down’, e.g. mounted on the top of the cog from the RHS feeding over the LHS, this is a mirror of how my motors need to work.
Code latest firmware and ground control v1.13 (NB should set the version comment in the ino)
Problem:
- Test motors all seems ok forward, reverse, little movement on the Z all happy.
- manually move Z all motors move!
There may be something simple, I checked the zip (speed) ties holding the motor board down, now the new glue has fused the heatsink theres no distortion or too much pressure.
Any steps or suggestions welcome, I will get some nylon spacers and longer screws to put some air between the mega and the CCA, however I’m extremely suspicious that will have any impact.
Happy to provide any tips, photos, config etc.
Cheers,
Guy
worked measured, then ‘added’ a couple links lifted, and set to sled from moto.
!!! Gcodes for Z? it’s well past the yard arm, so beer o’clock! and dig some of the steel shards out of my thumb!
NB Imperial measures (CDN by birth, Oz home now)
. If not, something is wromg.
