Does anyone know the the pinout of the z axis kit motor? I am playing around with some arduino programming.
Thanks
Thanks
The picture @Bar has shared has a so low resolution that it’s hard to read.
My guess is:
Kind regards, Gero
@Keith How and where did you get that? Tried all search methods i could come up with.
The post i have it from mentioned that Bar has put it on GitHub. I remember taking a copy from there with the same low resolution. Today i could not find it on GitHub within 3 minutes.
If that low resolution image is still there, it would be worth to replace it.
I think I got it from the mfg site, but I don’t remember. I downloaded it and have a copy in my photos along with the spec sheet for the other motor.
Something i would never do… i did ![]()
I abused my rights and edited @bar 's post here
Edit: and mine below
Next to find it on Git and a place to add it in the Wiki
It seems the setup is not a stepper motor. It is a standard DC motor with encoder feedback.
I am guessing Motor + is Vin… Motor - is GND. This is powered with PWM for speed control.
Does anyone know the format of the hall A and B output?
Defiantly no steppers on the Maslow in original version. All 3 DC with encoders.
Edit: Not sure if it helps, anyway:
Take a look at the system.cpp in the Firmware.
else if(pcbVersion == 1){
//PCB v1.1 Detected
//MP1 - Right Motor
encoder1A = 20; // INPUT
encoder1B = 21; // INPUT
in1 = 6; // OUTPUT
in2 = 4; // OUTPUT
enA = 5; // PWM
//MP2 - Z-axis
encoder2A = 19; // INPUT
encoder2B = 18; // INPUT
in3 = 9; // OUTPUT
in4 = 7; // OUTPUT
enB = 8; // PWM
//MP3 - Left Motor
encoder3A = 2; // INPUT
encoder3B = 3; // INPUT
in5 = 10; // OUTPUT
in6 = 11; // OUTPUT
enC = 12; // PWM
Edit 2: ‘Defiantly’ was not the word i was looking for… (foreign language member)
Kindly ignore that word. Perhaps ‘certainly’ would fit more ![]()
I think there has been some work on this in the forums. You might want to try a search on “encoders”. I would find some threads for you, but I am just on a quick break at work at the moment.
note the difference between the pins on the arduino/motor board and the motor
board/motor
they are very different
the hall A and B outputs are standard quadrature encoder outputs
k
Thank you. The word I was looking for was quadrature.
I am working on converting my maslow over to a more conventional XY rectangular system. I will make some post about this when I get there.
take a look at corexy.com that approach can make it so you only have the Z motor
moving (easier wiring) and can avoid having any chain under the workpiece to
collect sawdust.
Hi,
does anyone know what connector is used on the original z-motor, or at least that one from Makers Made?
I didn’t have the original one in my early kit, so ordered a replacement z-axis motor, assuming they all have the same connectors.
I now have the motor ( Z-axis replacement motor from Makers Made ) , but not the cable, and it seems to be with a smaller connector than the X and Y motor…
Could someone help out please?
Many thanks in advance
@marcething that is correct, the original motor also has the smaller connector. Maker Made is the same parts source as the original Maslow. Do you have a Z cable from a Maslow kit? or are you saying you have a 3rd chain drive motor cable? Or you need to get a cable for Z?
Super, Thanks a lot
