Z Axis turns the wrong wat.
Hoe can i turn it around?
Is it a stock z-axis?
On the Maslow, Z=0 is typically the top surface of the board, and Z moves in the negative direction to plunge into the wood. This is opposite from the 3D printer world…
If you’re using a non-stock z motor, look in the Settings for ‘Z-Axis Pitch’ - a stock motor uses a positive value, using a negative value reverses the motor turning direction
If you mean that the z raises when you press lower, just put a negative value as the z-axis pitch.
Where are you from btw? I think your name and your typo make it belgium or the netherlands
