Finally getting around to finishing up the setup of my maslow and calibrating. (so excited)
However while calibrating my z axis, whenever I plunge the bit moves away from the work surface, and if i raise it, it moves towards the work surface… is that correct?
When I set zero and go next, it moves the bit so my sled is lifted off the work surface (routers not running atm)
the best way to do this is to use a dial indicator, move the Z axis and see if
the indicator matches the distance you expect it to move.
In general, if you have the encoder, gear ratio, and thread pitch right, it will
be very precise, but if the gear ratio isn’t what the manufacturer claims it is,
you will want to do testing.
