Hello
I try to cut a text file (outline) with 1mm depth to plywood, some letters are 2mm others 3mm deep. And after go home, the Z-Axis is minimum 1-2 mm lower than before I defined zero.
My Z-Axis is working fine manually, raise 5mm…lower 5mm stops on the same position.
GC change the define zero and I don’t now why.
Normaly I work with 2mm safe travel height, change to 5mm is not helping.
– Ground Control 1.17
– Firmware Version 1.17
– Z-Axis Kit from Maslow
– Checked cables and connection, restart and updates.
Does somebody has any idea?
