I am trying to set up my Maslow for the first time. I am using a Mac running El Capitan. When I follow the steps in the assembly guide for Firmware Setup I get the below message when uploading to the Maslow. I open the Firmware, select the board type, select the processor type, and select the port that shows the arduino. I can even get the board info if I choose that option. No matter how many times I try I get an Timeout message. I do get a Done Uploading message at the end, but I don’t think it is doing anything because if I move on to Ground Control I cannot get the motors to work during the test even after setting the port in Ground Control I get a Timeout message also in Ground Control.
I did try the steps on a PC running windows 10 and I was able to get it to work corectly and test the motors, but Ground Control was glitchy, plus I want to run the Maslow from my Mac.
Help would be highly appreciative.
Matt
Message from Arduino app:
Archiving built core (caching) in: /var/folders/9b/l4rl7l495qnbdndjdb0np9pc0000gn/T/arduino_cache_794907/core/core_arduino_avr_mega_cpu_atmega2560_689ae5f81b8d103568be3d224f5a69d5.a
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:01:35
Copyright © 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright © 2007-2014 Joerg Wunsch
System wide configuration file is "/Users/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino9/etc/avrdude.conf"
User configuration file is "/(I removed this location for privacy)/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.usbmodem1D11
Using Programmer : wiring
Overriding Baud Rate : 115200
AVR Part : ATmega2560
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 10 8 0 no 4096 8 0 9000 9000 0x00 0x00
flash 65 10 256 0 yes 262144 256 1024 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Wiring
Description : Wiring
Programmer Model: AVRISP
Hardware Version: 15
Firmware Version Master : 2.10
Vtarget : 0.0 V
SCK period : 0.1 us
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x1e9801 (probably m2560)
avrdude: reading input file "/var/folders/9b/l4rl7l495qnbdndjdb0np9pc0000gn/T/arduino_build_829115/cnc_ctrl_v1.ino.hex"
avrdude: writing flash (53688 bytes):
Writing | avrdude: stk500v2_ReceiveMessage(): timeout
#avrdude: stk500v2_ReceiveMessage(): timeout
##avrdude: stk500v2_ReceiveMessage(): timeout
***This message shows up on the message bar***
Done Uploading
