I am living in Germany so the affordable Ridgid R22002 is sadly not an option for me.
I thought about the BOSCH with the z-axis modification from @Ned with the guide from @Dag83 and additionally the auto z-axis adjustment
This is an good and cheap solution in my opinion, just one thing I am not getting behind…
…how do you manage the tool changes for example between to seperate workjobs (Like changing the V-Bit from lettering the sign to the normal bit for cutting the sign) without loosing the position?
best regards
-kompass
PS: I am stoked from all this Maslow thing and my set should be here soon … the Frame is already build
Thanks for the answer @Dag83 .
I actually will use MakerCam in the beginning to do my GCodes out of the Designfiles. Will probably just go for the separte GCode Version.
One more question. I read the POF1200 articles but I am still not sure… is it necessary to cut the handles of the BOSCH away?
I read someone writing “happy that there is no need to cut them” but actually I cant find the solution for that.
