I built a horizontal frame, my vertical frame isn’t going to work as I built it not knowing that the Maslow needs to be constantly unmounted and remounted.
My old vertical frame I changed the Z order of the spindles for clearance.
I didn’t switch it back as it shouldn’t matter.
I accidentally started calibration in vertical mode, and noticed TL and BR tightening With TR and BL slack. That seems weird, it should have been TL and TR as it was gravity fed…
I stopped it, set it to horizontal, rebooted. Started the calibration process again.
It’s still doing it? Shouldn’t all 4 spindles be tight for horizontal calibration? They’re practically tangling.
The end state has all 4 taught, but it’s saying fitness is like .04. My vertical frame had .70.
There’s no way. Is it somehow confused as to what motor is TR, TL, BR, BL?
I did lower the calibration torque from 3000 to 1000…I can change that but it almost looks like the wrong motors are moving…that seems impossible…you can’t really mix up the controller wires.
I did also update the firmware…I am almost thinking I should re-flash it from the command line… something is super wonky?
