Tested Routers List
(from the old Maslow CNC Wiki)
A collection of routers tested by the community:
In addition to the details below, a matrix of the different routers, their features, compatibility with the different triangular linkage kits etc is available here
Recommended:
- Ridgid R22002
- AEG MF 1400 KE (European re-brand of Ridgid R22002)
- [Ubermann UBNEW20] Latin America re-brand of Ridgid R22002
- Bosch POF 1200 AE (Conversion kit available from @Dag83)
Below are a few Palm Routers which are smaller and need their own Dedicated Z axis.
Makita 701C 120V USA version https://thd.co/3iO6gaM or
https://amzn.to/3gaGyeQ
or 240V European Version: https://amzn.to/3aD0zcY
there are many clones of the above makita router for example this 240v $40 clone https://amzn.to/2Fu5ZLQ or in the USA there is Enertwist, Avid Power, or VOLTEK. They appear to be all the same except for different branding and colors.
One will need to buy all the parts below to make the dedicated z axis to move the router up and down. the motor shaft is 6.35mm and the lead screw is 8mm diameter. the last item to mount the z axis motor will need more holes drilled in it to fit the 37mm z motor
xrt136
Testing
Tested but found to be difficult:
Please Help contribute by creating a new page for any other routers you may have tested. Each router page should include at minimum the following information, an identifying photo, and a link to the manufacturers documentation.
| Feature | Value |
| Model # | |
| Cost (approx) | |
| Collet size | |
| Ease of attaching Z-axis | |
| Shaft connector size | |
| Variable speed (y/n) | |
| Illuminated (y/n) | |
| Dust collector (y/n) |
Pros/Cons, General comments
