My maslow is coming soon. I need to order some bits. Not sure the best ones as I see some projects with alot of tear out and others that are just a clean cut.
Is that because of the bit or because of speed at which the design is cut?
Also are there different bits some vets have known to work better with different qualities of plywood?
Upcut bits can cause tear out issues on the top of the wood.
Downcut bits can cause tear out issues on the bottom of the wood (and can cause fires if you attempt to drill holes with them or use them without a vacuum attached)
Compression bits try to be the best of both worlds, reducing tear out on both the top and bottom of the board. They work best on plywood and laminate, not solid wood.
compression bits only work if you are cutting the full depth of the wood in one
pass.
straight single-flute bits work well and are a lot quieter than the spiral bits
sold by maslow
This is not true for plywood. Compression bits work fine in plywood, provided the first pass is at least the depth of the start of the compression flute (on the maslow bits, i think this is .15 in) into the material.
Some plywood is better than others. I’ve cut a lot of luaun underlayment because it’s cheap (cut several sheets into blanks when I got my first CNC router, still have a drawer full) and it’s prone to chipping. Experiment with first pass DOC and feed rate if you want to learn more.
Luaun looks nice with a bit of sanding and a clear finish…
