I’m currently trying to use the anchors found in this post:
In the process of trying to calibrate and set the machine up, I’m having to extend and retract the belts A LOT. These anchors require me to unthread the bolts every time. I already have them printed and adjust to the spoilboard and workpiece thickness. i would like to insert a link between the bolt and the end of the belt so I can use a quick release pin to attached the belt end to the anchor and leave the bolt in. Here is an ai generated sketch of what I’m proposing. Will this work? Do I need to update the belt lengths in the firmware some where?
This would work. Does the orange part rotate? If it does you would add that number in mm to the “extensions” number in the Yaml configuration page. You would measure from center of pin to center of pin. If the new part doesn’t rotate than you wouldn’t have to do anything.
Yes, it would rotate. I’m imagining it like a link in a bicycle chain. Thanks for the response.
It’s been a minute since I’ve checked in on this or tried to get my Maslow up and running. I’m having a hard time finding the most up-to-date documentation. Is it this? https://documentation.maslowcnc.com/
Or where would you recommend finding the best info for current firmware and setup instructions?
Yes that is the current best documentation. It is built as a wiki in the github and then automatically turned into a webpage. write here with questions though and we’ll try to help.
If the link is standard 3d printed I fear it will not be strong enough. The belts pull about 50 lbs plus when running. Be careful there. Especially in your design at the thin right angle shoulder where it expands up and down for the quick release bolt. Keep it simple, square hollow steel rod with holes drilled through?
It will work as an arm extension. They need to be identical on all four arms. Then you find extensions in the config editor screen and change that to 30 mm (the existing belt end anchors are 3 cm) and add the center to center length of your link to that.
Here is what I built, I bolt these down and just drop a bolt in the top to hold the belt end (if I bother, I cut the threads off of a bolt and bevel the ends to make it easy to drop in)
So the if my link is 70 mm center to center, it would be 100 mm in the beltEndExtension right?
Looking at shear capacity of fdm prints, the capacity of my link should be anywhere between 300-1000 lbs in a shear failure mode. It should be about as strong as the stock belt end connector assuming I print it correctly with 100% I fill and at a hot enough temperature. I can also use carbon fiber reinforced filament to increase the margin.
yes
it isn’t the link that would worry me, it’s the tower. I had to beef up my
towers after one snapped and flew about 20 ft from belt tension.
I use a 1 inch foam board so I would need to shorten these standoff by 1 inch to keep my belts parallel to the floor?
Yes, one of the configuration parameters (top left) asks for the height from the
ground to the bottom of the lowest arm’s belt end (when retracted)
(I also have some tweaks to allow for there to be custom tweaks to the height to
handle uneven ground, that is why some features show red, you can ignore them)
Thanks for sharing the snapped-tower story, David — that is a useful warning to keep in mind alongside the anchor itself. Hope the concrete setup works well once it is dialled in, and thanks for posting the update.
I think the standoff I’m using should be ok. You can crank on them and put them in compression which should help offset the tendency of 3d prints to be weak along the layer lines. The down side to them is the need for long bolts and this extra link I’m designing.
