Has anyone tried making dovetails with the M4? I see a lot of finger joints with cnc projects, but rarely dovetails. I understand that finger joints are easier, but I would think dovetails would be doable with only a switch to a dovetail bit. The tails (i.e., the part that looks like a trapezoid on the board face and rectangle on the end grain) could be cut with a standard bit since it is just cutting out a trapezoid shape. The pins (i.e., the part that looks like a trapezoid on the end grain) could either be cut with a dovetail bit for best accuracy (this would cut the pins with the wider side of the pin down against the spoilboard) or could possibly be done with a standard bit that steps down and inward along the dovetail angle (this would cut the pins with the wider side of the pin pointing up towards the M4).
In my head, it seems to work. Has anyone tried in practice?
