Error 9, z motor not moving
z motor doesn’t move
it starts the fan, that stays on
I tried “go to z home”
and got error 9
(power cycled five times)
Serial Messages
Index.html Version: v1.23.0
[MSG:INFO: Zm=-5.260mm, Z home=4.000mm, Z position=-9.260mm]
Retract All
[MSG:INFO: Succeeded]
[MSG:INFO: Bottom Right pulled tight with offset -1925.058]
[MSG:INFO: Top Left pulled tight with offset 0.247]
[MSG:INFO: Bottom Left pulled tight with offset -1916.738]
[MSG:INFO: Top Right pulled tight with offset -0.086]
JogTo: $J=G91G21F300Z5 (mm)
Moving to Z Home position
error:9
turns out all it needed was a sixth power cycle. (I was unable to delete this topic)
This says your Zm is a negative (below the minimum of 0). If you get this again, lower the Maslow all the way down, then go to setup, then Set Z-Stop. You will then need to reset Z-Home so bit is just above your work surface.
