Going thru the set up process and I’m stalled on getting it calibrated. Keep getting fitness too low alerts. One thing that stands out as I go thru the log file is this:
“[MSG:ERR: Configuration file:maslow.yaml]”
I believe I have everything updated. Went thru that process twice. Any ideas?
Full startup serial log below. I can add log files fro my failed calibration attempts if that helps. Just trying to eliminate one issue at a time.
Thanks!
-Russell
Serial Messages
[MSG:INFO: FluidNC v0.75 (Maslow-Main-e2ef1bb2-dirty)]
[MSG:INFO: Compiled with ESP32 SDK:v4.4.4]
[MSG:INFO: Board Maslow]
[MSG:INFO: Axis count 3]
[MSG:INFO: Motor0]
[MSG:INFO: Config messages ran]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor1]
[MSG:INFO: Connecting to STA SSID:Hatchersons]
[MSG:INFO: Connecting.]
[MSG:INFO: Connecting…]
[MSG:INFO: Connected - IP is 192.168.0.122]
[MSG:INFO: WiFi on]
[MSG:INFO: SSDP Started]
when you updated, did you update all three files (firmware, index and yaml?)
I think that as long as it’s complaining about the yaml file, you need to
resolve that before worrying about anything else.
Hey, I did upload all files. However I am unclear on whether I should have deleted the old index and yaml files first… I just uploaded the new versions expecting that it would overwrite the old.
I just went back to the previous week’s release (0.75). and the error code is now gone. I’ll update on the rest of the process when I have run some calibrations
once you have a good calibration that you are happy with, you don’t need to do
another when you upgrade, just record the anchor positions (the Maslow_*
variables in the yaml file)
I got an error message about corrupt Yaml file or something last night in the terminal, so I decided to re-upload the fresh .76 version with my calibration numbers. The deleted file was 5375 bytes, And the fresh one is 3418 bytes. I’m just wondering what causes the file size to change? Obviously there is some writing going on? Just curious so I can better understand how the file might corrupt?
Yes, I would suggest that if it does change, save a copy before you replace it
so we can see what happened.
We do know of a failure mode that will overwrite the file in a way that risks
actually damaging the machine (the Z steppers get very hot), I think a fix for
that is going in this week (if it didn’t get in last week)
This occurs because, as calibration is performed, a fresh ‘dump’ of the entire configuration is written back into the maslow.yaml file. This includes lots of FluidNC values which are not considered ‘important’ for the M4, but that are the ‘default’ for the corresponding setting in FluidNC.
It also occurs when you click ‘Save’ in the ‘Setup’/‘Config’ drop down.
