Firmware version? Help!
I have not yet been able to calibrate.
Retract and Extend seem to work.
When I “TEST” the system reports index version 1.07, but firmware version 0.87.
I thought the current version is 0.88.
One other thing - I’m getting “error:3” twice with every attempt… How can I find out what it doesn’t like?
Here’s my log:
Calibrate
[MSG:INFO: Center point deviation: TL: 0.121 TR: -0.030 BL: 212.081 BR: 14.712]
[MSG:ERR: Center point deviation over 100.000mmm, your coordinate system is not accurate, adjust your frame dimensions and restart.]
Do I need to adjust the extend distance? The BL belt stays loose.
After powering off and on:
Serial Messages
Index.html Version: 1.07
[MSG:INFO: FluidNC v0.87 (Maslow-Main-ec171155-dirty)]
[MSG:INFO: Board Maslow]
[MSG:INFO: Axis count 6]
[MSG:INFO: Axis X (-1000.000,0.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Axis Y (-1000.000,0.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor1]
[MSG:INFO: Axis A (-5000.000,0.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Axis B (-5000.000,0.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Axis C (-5000.000,0.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Connecting to STA SSID:dunes]
[MSG:INFO: Connecting.]
[MSG:INFO: Connecting..]
[MSG:INFO: Connected - IP is 192.168.68.105]
[MSG:INFO: WiFi on]
[MSG:INFO: SSDP Started]
error:3
error:3
you need to upgrade both to the same version nos see the following guide
(6) Installing Firmware 1.0 - YouTube
This is a onetime upgrade where you have to use a usb cable to your PC. Make sure your USB cable is a data cable (some are power only).
Hope this helps
Thanks! I’ll try that tonight.
