I can tell everyone that I got to the point of documenting the nomenclature for worm geared motors with encoders as well as specs. After awhile you start to see similarities between manufactures.
Just to note the link above that was offering up a motor: I was not able to quickly get the specific info needed but I am pretty sure that one was a no go due to either low torque or max amps.
Although the motors are configurable (If purchasing large amount) we basically have to look for the leftovers of big orders that are being sold on AliExpress, eBay etc.
For those new to looking. You need to find worm geared with encoder (best to keep close to original for compatibility) so the following are important factors. Some can be worked around depending on skills but if you were widely skilled and had the time, just design the power from the bottom up.
Torque rated torque of 30kg cm / now simply for the chance to have something to build and still be involved in the project I broke down and picked up a couple very cheap, small worm geared motors with only 16 rated torque…but with my planned built it may function…we shall see.
They are 12 volt, 324:1 ratio, 11ppr encoder, and way less than max amps (forget right now). You must keep alot in mind…need torque high so high ratio, but keep in mind if you go over 291 you are going to be sending much more signal pulses. Pulses equal to ratio x 11 x 4.
It has not been established, from what I have read, the max pulses able to be handled by cpu. Now i do not know if it will help but when wiring any signal wire best practice is to not have near power wire and if you must cross it, do it at an 90 degree angle.
I think I was able to source a motor that almost hit the original specs but cost like 90 each from robot seller. If anyone interested I will dive into my logs and dig it up for you, otherwise, I am holding off due to funds and the fact that I am building with what a have at this point. Note…my sled is much lighter than the original maslow, plus, have planned to experiment with the sled idea that centers on the mill itself…as I had planned to do that from the beginning after researching plotters.
