I’m starting off in a VM (in my case KVM+Virtual Machine Manager)
I downloaded the latest 32bit Ubuntu Mate, in my case this was
http://cdimage.ubuntu.com/ubuntu-mate/releases/16.04.3/release/ubuntu-mate-16.04.3-desktop-i386.iso.torrent
I first installed and updated the whole system.
A few things i did to make my life a little more comfortable:
I installed Synaptic
sudo apt-get install synaptic
added the quick search
sudo apt-get install apt-xapian-index && sudo update-apt-xapian-index -vf
Synaptic + quick search allows me to find packages that I sometimes forget about, and it’s faster then google + dwelling trough distractive forums
Add myself to the dialout group. This to enable the serial communication to the Arduino that controls the Maslow
sudo usermod -a -G dialout <enter_your_username_here>
Now i installed Kivi. Turns out that on Ubunt-Mate i have to do a few extra steps.
sudo add-apt-repository ppa:kivy-team/kivy
sudo apt-get update
sudo apt-get install python-kivy
the next section is replaced
Install pip
sudo apt-get install python-pip <---- (this step is not mentioned in the Maslow wiki)
pip install --upgrade pip <---- (same for this, to upgrade pip to the latest version)
Install pyserial
pip install pyserial
the above pip stuff can be skipped by installing pyserial from the Ubuntu repo instead
sudo apt-get install python-pyserial
To clone GroundControl i’ll do this a little different then described in the Maslow Wiki
First i install git
sudo apt-get install git
Now clone GroundControl
sudo git clone https://github.com/MaslowCNC/GroundControl.git
this creates a new folder /GroundControl/ in your /home
now enter the /GroundControl folder and try if CG actually works
cd ~/GroundControl/
sudo python main.py
in my case all is good.
and i have an actual VM with a working GC
I plugged in an Arduino Mega that has Maslow firmware installed
it got recognised as /dev/ttyACM0
In the VM i now enabled this USB device to use with the VM
And YESSSS GC spotted right away that my firmware (0.97) is out of date
I also installed skimage
sudo apt-get install python-skimage
This so that dlang’s v-plotter.py script can be used
Next step will be downloading and installing
Also this would be better on a 64bit distro So from that point of view i think it’s best to not add CAD software to this simply because that would work much nicer on 64bit machines.
