I cannot thank you all enough. I appreciate it so much. One more problem though, I cut it small. Is there a way to resize the G-code file easily? I’d like it about 3 or 4 times larger than it is.
Excellent work!
There isn’t an easy way to change the size of the design in gcode, but you should be able to make it bigger in the CAM program which generates the gcode pretty easily and it will usually save all you settings (depending on which software you are using) making it quick to regenerate the file.
Ah, that makes sense.
Thank you very much!
Hey that looks like the gcode I uploaded from the previous topic.
Let me know what you want for dimensions and I can size it.
Yes, it was. THANK YOU SO MUCH!
I would love to cut around 8”x10”
I truly appreciate you doing that for me! Someday I will pay it forward when I learn to do this.
No need to scale the file up when you can use a smaller bit. ![]()
I just told my wife that I should’ve used a smaller bit!
. Still, I would like it a little bigger.
