Hi,
My Maslow stoped in the middle of a job ( even running of the Gcode path).
I was on firmware V0.78 so I tried downgrading to V0.74 (no issues there).
After restart I can see the MASLOW wifi and connect to it but I am unable to connect to the maslow via the browser @ IP 192.168.0.1.
I stalls…
On the maslow I only see the green led turned on constantly.
I searched the forums and saw an option to reset to factory settings, but I am on a MacBook and can´t get the full install.bat running.
Are there any other options or did someone ran into this issue before and found a solution?
Appreciate the help!
Were you able to reconnect?
To me this sounds like the Maslow is not connected to your wifi and is instead probably creating a “maslow” wifi network, do you see that network?
