Okay, thanks. I’ve been confused on that since 1.27 isn’t an “official” release yet. GitHub confuses me…I wasn’t sure if the recent merge that Joshua did included the unreleased v1.27 or if it only included 1.26. I think I understand it now.
I’ve gone through what appears to be all the commits in 1.27 and there’s quite a bit. Nothing that I could readily find that would hang up the B10 command.
I’m not in a position where I can do any testing (and probably needs to be done on your machine anway).
When you can, try to issue a B10 L command from a macro and see what reports back. If it doesn’t report back a measurement (it might appear in the terminal and ui screen, but definitely in the log) then if you are willing to edit the firmware in arduino ide, I can make a couple suggestions that might be able to tell us where the problem is occurring.
I’ve studied the code further and it appears that the chains are pulled tight and continuously pulled tight (motor is still pulling) until the command is issued to provide slack. The problem that’s coming up is that the measurement function, which happens after the pull tight but before the slack commands, is never completed and therefore the slack command never occurs. With the motors running full speed, I suspect there’s a stall condition, the power supply drops out, and then the controller resets. This is evidenced by the USB disconnect after the measurement command is sent (i.e., motors still pulling tight).
The reason that the motors are still pulling is that the motors are never told to stop pulling. I think this is a flaw in the B11 implementation that’s been there for a long time. The B11 command uses motor.directWrite(speed) which tells the controller to turn the motor on and run at a certain speed (pwm value). It issues this command for 3-seconds but never tells the motors to turn off with a motor.directWrite(0). So the motors keep running at the last PWM level until another motor command is received… which is normally the chain slack command… but since it doesn’t get reached (for some reason) it keeps pulling.
The B4 (motor test command) does both directWrites… turns on motor at a given speed and when done, stops it with a directWrite(0). B11 just does the first one.
None of this addresses why the measurement isn’t working, but I think it explains why the motors keep pulling.
I think we are on the right track for figuring out what’s the culprit. I suspect someone may need to put some debugging ‘println’ statements into the firmware’s B10 command to figure out where its getting hung up (or if something else is occurring).
To test - ** disconnect the chains **, set a macro to ‘B11’, and run the macro. Without the patch the motors run indefinitely; with the patch they stop after three seconds as intended.
I had the problem with the latest fw/gc from Joshua’s fork.
TLDR: the Acer laptop I was using blew it’s MB the SSD is soldered to the MB so no convenient way to recover the GC.ini. I connected a different pc and started reinstalling. Once everything was set on the official MaslowCNC GC and FW I backed it all up and installed the latest Holey GC/FW from the SchmittJoshC fork and tried the calibration. No joy on the pull and measure routine.
I’ll try the B10 command this evening.
BTW: I want to end up on webcontrol when it’s all said and done. which firmware does it support?
It should support any of the stock firmware versions off the maslowcnc repo. Holey calibration adds a bunch of new settings and, of course, the entire calibration methodology that hasn’t been added to webcontrol. It’s not a trivial undertaking.
