george
1
Receive following message after inputting measured triangular pattern figures:
The machine was not able to be calibrated. Please ensure the work area dimensions are correct and try again.
Check mm v. in.
Not even sure where the work area dimension are set or what that means.
bar
2
Are you seeing this error at the end of the calibration process?
This usually happens when the math can’t find a value for the chain sag correction which isn’t negative (which would make the chain lighter than air).
Just to establish some baseline sanity I would try doing manual calibration:
And then to dial it in run the test pattern:
george
3
(in)sanity check test cuts here:
EDIT: And no I saw it after running Advanced>Run Triangular Test Cut Pattern it was upon clicking Enter Values
