I’m cutting a strawberry cutting board in Makerverse and 12 minutes into a 40 minute program it stops and gives me a soft limit error during a travel path that it has already taken 10 or so times to cut that portion of the shape all the way through. I’ve attached the g-code and a picture of the issue. I had already tried to restart so the error message was closed but it won’t let me and I had to reset the board which stops the program.
Large strawberry cutting boards (2).nc (217.2 KB)
I’m having this same problem… did anyone respond to this post?
it must be a z axis depth soft limit. you can disable the z axis soft limit with $20=0 or add more depth to the z axis limit with $132=50 or 100 instead of the default 25. screen shots here.
Thank you Orob!
