Thanks @jwolter
My maslow is comming today and i was reading through the assembly instructions and the arm assembly seemed the most confusing. So perfect timing
Looking at this it looks like I have my top two arms installed in the wrong order. I wonder if this is part of my calibration problems? Seems likely. Now to decide if I want to disassemble and fix it or change the heights in the yaml file.
yaml file.
if they are still pointed in the right direction for where they are plugged in,
you can just change the anchor heights.
the suggested order was picked so that arms pulling in opposite directions are
near the same height to reduce tipping as you move back and forth. I donāt know
how useful this is as it seems to me that you spend more time changing direction
(which goes from the bottom set of arms pulling to the top set of arms pulling)
then you do reversing direction.
Thanks! that will be a ton faster than disassembling and reassembling, and I can just document my correct values so that if I ever have to wholly replace a maslow.yaml again I remember to do. Also I think tipping is probably less of a problem in a vertical orientation.
OMG you are an absolute HERO!! This is 100% what we need to make that step more clear.
The order is somewhat important to balance out the forces on the machine also, but if you donāt have any issues with tipping then donāt worry about it.
Adding a link to some feedback in a different thread.
And another one.
I used a torn-off piece of the superglue blister-pack. ![]()
(Hunh, it renumbered the list for me)
To respond to my own thread (which is elsewhere)ā¦
The fan only runs when the motors are on, thats helpful to know.
I had to really crank up the initial torque to get things retracting. Not sure if that has anything to do with the tight tolerances on the idler shafts (and the judicious use of a hammer to get them to seat) or what. It seemed each motor wanted itās own amount of juice - None at the default 1400, first 3 at 1600, 1700, and 1800, and the last little bugger didnt budge until I cranked it up to 2700.
It looks like a beast! Iām going to have to finish up some of the other projects ASAP!
it turns out that the motors have some play in them as you tighten them down, if
you move them away from the idler before you tighten them down, it doesnāt take
as much current to move everything.
Thanks for that feedback, great observation. Even as I was putting it together, I was thinking that pointing out the collet to indicate that the router is pointed toward the user is good, but perhaps too subtle. I didnāt even think about the orientation of the arm! If it confused you, it will undoubtedly confuse others. I added some explanatory text to explicitly address the orientation of both parts. Howās this?
ā¦and because I believe in right to modify, hereās the svg source for the png above. @bar, I recommend using the png because I noticed my browser shifted all the text when you added the svg to the guide.
Iāll update the guide! Great work ![]()
I need replacements for several of the magnets, dropped them and canāt find them.
Shoot an email to Anna@maslowcnc.com and weāll send you some
I had to disassemble/reassemble my M4 and several of the arms recently, and I thought Iād share some feedback.
I had the same issue others did, where I tightened the motor to the arm first, then put the drive and idler gears on, and it was a very tight fit on a couple of my arms. At the time, I considered loosening the motors and adjusting the fit, but decided to just forge ahead. Turns out that was not a problem. I did have trouble with my first retract all, but after a couple of extend/retract cycles, all was well. When I disassembled the arms later, none of the idler gears were tight to the motor gear like they were when I did the initial build. I suspect the force the motors apply is greater than the clamping force of the machine screws, so the motors drifted to a good location.
Second surprise: when I disassembled my arms, all of the grub screws holding the motor gear on to the D shaft were loose. I could easily remove the motor gear by hand on all but one of them. I blame this on doing the initial assembly with a stubby T8 driver instead of the supplied 2mm allen wrench. I dug out the allen wrench and torqued the grub screws good when I reassembled.
Another minor change when I reassembled the arms and uprights on the router, I put the arms on, then put the bottom clamp on and connected it to the uprights before tightening the clamp. That seemed like a good idea to me so you have a solid stack clamped to the router, instead of possibly having the top and bottom clamp attached to the router and possibly pulling against each other.
And last, I discovered that the router base that came with my DeWalt router makes a good holder for the arms during assembly:
And that reminds me, if you have to take an arm apart, but painterās tape over the side with the nuts to keep them contained. And cut up credit cards are great to slip between the halves of the arm to get them to separate.
Hope this helps someoneā¦
Russ
Out of curiosity, did you apply Loctite to them when you installed them?
No, I donāt think it was suggested in the instructions, so I didnāt use the threadlocker on those. In hindsight, maybe I should have. Given the issues Iām having, I expect I will be doing more disassembly soon, if I notice the grub screws are loose again I will probably put the threadlocker on them.
Youāre right thereās no threadlocker in the instructions. I donāt recall if I put some in anyway. I think itās a good idea. @bar
A few items (maybe some of them repeats, sry).
- The guide was overall great and easy to follow with straightforward chunks and great photos. Iād chunk it up even more and make a little more robust table of contents so folks can easily jump around as they troubleshoot later on.
- Torque: This is bound to cause much hubub, but I think at least some of the bolts should be torque specd. Hereās why: Itās pretty easy to strip, peen or break something when going through the assembly. Even with a ginger touch, there are some steps that require a certain amount of pressure to mate two surfaces or bring something into alignment, which makes tightening with just the right force a bit tricky. Bring the hate!
- A calibration troubleshooting guide would be awesome! It seems to be giving enough folks trouble and there seems to be a critical mass of workarounds that are seeming to work that collecting them in official documentation might be nice. SEEMS!
(This all feels very whiny considering I donāt have much, any, time to contribute back.)
This was one of the hardest steps for me too. I used m3x14mm bolts instead of the regular ones and it made it much eaisier. Maybe add 7 of the long bolts to the kit instead of just the 4 for the fan?
