I was wondering how well it would work to make a smaller frame to handle only 4’ by 2’ sheets in place of the normal 8’ by 4’. My idea is to take the Bar Bolt Frame and simply shorten the top 2x4 from 10’ to 4’. This should give a portrait workspace of 2’ by 4’. But would the accuracy be any good in the bottom corners? I did a v-plot, which looks OK. With only 2’ by 4’ it is of course important that the entire workspace is usable, so there would have to be skirts to support the sled as well.
I really get thrilled by the idea to have my very own cnc standing in the shed. I just hope it would perform reasonably.
I have no proof of this other than using my 4x8 maslow for a few weeks now, but I think you would have much better luck (accuracy and issues) running it in the 4 by 2 style rather than the 2 by 4 orientation.
Yes, I do realize that landscape would be better if there was no space constraints. But if the top can be a maximum of say, 4’ or 5’ wide. Then surely a portrait setup will give better accuracy.
So basically to get the same .18 ratio as the stock frame on a 4’ by 2’ workspace you need
with landscape mode a 5.26’ top beam
with portrait mode a 4’ top beam
And a longer top beam should i theory give better accuracy in the bottom corners. I hope I will be able to fit a 5’ top beam on an portrait mode frame.
