I was trying to set home to lower left corner and got confused when I jogged the Maslow4 to that location. The left pane graphic that shows Maslow4 location showed it traveling all the way to left, but it would never show negative Y movement. If I jogged M4 up, I would see positive movement, but jogging down to Y: -200 and the pink location dot went down to Y:0 and then stopped, even though X,Y location numbers correctly showed Y: -200 and the actual Maslow4 also moved to negative 200.
OK, It may just be that the graphic screen doesn’t refresh because if I click on it 2 ro 3 times it starts to show the correct Y location (my bad)
