I can no longer access the software in my Maslow4.
After an update to the latest software version, access disappeared completely.
I have also tried 192.168.0.1 to no avail and no local maslow network can be seen.
The Maslow4 diodes blinks, otherwise nothing else.
Can you try refreshing the browser and clearing the cache (Apple+shift+r on Mac at least)? Trying a different computer or web browser would have the same effect
Tried with new computer without success.
Re reading this and looking at the video, the blue light blinking is telling us that the machine is connected to your home wifi network which would explain the fact that 192.168.0.1 won’t work and that there is no Maslow wifi network.
Can you try going to maslow.local?
Locasl is misspelled as ‘Lokal’.
*Local. How emabarassing…
*embarassing
I can think of three options to try next.
Turn off your home wifi or move the machine somewhere that it can’t connect to that wifi network and then turn it on. That will cause it to create the “Maslow” wifi network to connect to again
Count the blinks on the blue LED, that will tell you the machine’s IP address on your home network
Factory reset the machine by connecting to the USB C port on the back and running the full_install.bat file
Thanks, for the tips I will try to try them tomorrow. As an old man, I need some rest in between.
Turning off the home network helped, then the FluidNC network appeared and I was able to access Maslow4 again.
Thanks for the help and patience with the old man.
Great work! I’m glad to hear that it worked.
