MaslowKinematics
First time calibrating.
When I click on find anchor points, it gives me the following messages:
[MSG:ERR: MaslowKinematics not available]
And then it disconnects, and I can’t connect to it again unless I restart the machine.
Any suggestions.
And then it disconnects, and I can¢t connect to it again unless I restart the machine.
that sounds like you don’t have a valid maslow.yaml file to start with, it’s
trying to read some data from the file and it’s not finding it.
what firmware version are you on? make sure the index.html.gz matches your
firmware
To check versions, click on the test button in the setup menu. You may have to load/copy the maslow.yaml file as well
Im on Firmware Version 1.15
Ok so when I imported the new firmware, I also updated the Index file, but not the yaml file. Should i update the yaml as well?
Ok Updated the YAML file and its starting calibration. I saw in the video that you mentioned it can take up 10 times to get a successful finess level.
I am running through 32 before calling it quits.
Any suggestions.
From looking at the data in the log nothing is jumping out to me as being wrong, but I am also not able to get it to find the anchor locations from that data.
It’s close, but something is slightly off.
I would either just try it again, or maybe try increasing the calibration force slightly:
