This is a companion discussion topic for the original entry at http://maslowcommunitygarden.org/Mudroom-Storage-Bench.html
Can’t wait to see how it turns out. It’s exactly what I need to build as well.
Hello - I have downloaded the files which are .stl. I am trying to find a way to convert these to .svg or .nc. Whenever I open the files in some software to try to convert they come up in various lengths (1-2" typically). What method are you using to convert each file (which has multiple parts) into g-code or svg files that I can use with Ground Control? Any advice you have would be greatly appreciated as I am still learning the various CAD software packages.
Hi, so the way I convert it is I use kiri moto in onshape Barr has a decent tutorial on youtube https://www.youtube.com/watch?v=mt2JFI3vJso. I haven’t had any luck converting stl or svg to gcode, usually if I come across those files, I reCAD it in onshape by eye.
Update as well, it took a year of calibration and mostly procrastinating interrupted by ski season, but it’s finally complete!
