How do you purchase items from the community garden.
I cut my MaslowCNC Zaxis cable today during the cut
Thank you,
James
Thank you,
James
I guess they should be on https://maslowsurplusparts.com/ but are not showing yet.
Thank you, just ordered one!!!
And how did you find it? Feedback please
I think they were just added, and it takes a bit of time for a moderator to go
an and approve them for the store.
I clicked on the catelog under the menu and the cable was listed there among other parts
Was able to pay via PayPal
The motor cable that I’m seeing has the ends that match the main motors with 2.2mm connectors - the z cable has one end with a 2.0mm connector and one with a 2.2mm connector. Don’t throw away the parts from your old cable
If you go to https://maslowcnc.com and click on store, it now takes you to http://maslowcommunitygarden.org/?market=true.
PM me your location if you are in the US I can ship a Z side connector. I just got some.
I need to extend my Z axis cable. Apparently Maslow Surplus Parts is sold out of both motor cables. Does anyone know if these parts will be restocked? Or is there a good source for the ribbon cable?
Thanks.
Digikey lists this for ~$3 per foot…
You could use any stranded 22 gauge wire to extend the cable you have by cutting in the middle and soldering in extensions. That would probably be more secure than adding a pluggable extension onto the end, adding another point of accidental disconnect.
Thanks. I might come to that: using ordinary wire spliced in the middle of the existing cable. My thought was I could find another Maslow motor or z-axis cable I would trim an end off each and solder them together for the extension. This result would be much neater.
Hi,
I’m unfortunately not in US, but near Antwerpen Belgium.
Could you point out where to get these connectors ( or what they are called ) , so I could order some please?
I think a network cable would be fine for the wiring, just need the original connectors.
Many thanks in advance
Marc
Friends, I need a Z axis cable also but there´s no option on http://maslowcommunitygarden.org/?market=true and Shop - (only XY cable)
I know Z axis cable has 2 different plugs. Can someone PLEASE indicates me what kind of plug and wire this cable is made? so I can search on ebay or aliexpress for options.
Thanks !!
The larger end is a JST XH connector, the smaller one is I think a JST PH although it’s been a while since I speced that. You could have one made, but my guess is that if you email the folks selling kits now they’ll be able to sell you one. They probably just don’t have it listed because not enough folks ask for it.
I have some Z OR XY cable $12 | MetalMaslow
Hi friend.
You didn’t ship to My country, Chile…
Thanks
yep you have to use a USA package forwarder ,not worth the hassle for small items like that. given the shipping costs, much cheaper to fix the connectors that break then buy entire cable. contact whoever you bought the kit from and they can help you hopefully.
