My Z axis is reversed and I see no way to set it to go the right direction. My cables are tight, everything moves as it should other than z axis. Even jogging the machine manually, it runs backwards. New user so need help please
For whatever reason, it’s decided to move the right direction now. No clue as to why, just closed software and restarted
If it comes up again there is a setting for that. Just set the mm per rotation for the z axis to be negative and it will go the opposite direction
