I just purchased a kit with some bits and the Z axis. Plan to build the frame in a few weeks as i clean out and make room in my garage.
What all do i need to get thats not in the kit? From what I gather I need to build the frame, center mount, and bricks or weights. The kit comes with the Arduino Mega 2560 from what I see, right? Whats the recommended setup for a nerd? I have a RaspberyPi for my 3d Printer i built. How does GroundControl function on a PI vs WindowsPC? Just not all familiar with the “extras” on the Maslow.
On the frame, I plan to put it on wheels to easily move it around in my garage. I plan to use these Adjustable Wheels? Any thoughts or recommendations from others with wheels or a current build?
Bungee cords on frame. It appears there is alot of talk around this system and was wondering if anyone has tried using bungie attached to the chain end and looped around pulleys back to the router board with a S hook or clip? Not having built the frame, could be completely stupid and missing something not seeing it in person.
Frame Tilt - Is there any need to have some type of adjustment for the tilt of the frame? It seems I’ve heard between 8-15 degrees is typical?
Router - Plan to buy the Ridgid R2200 from HomeDepot and remove handles for the ring system and also purchased the Z Axis system. I think i’m good here, but plan on putting some kill switch into the system.
Vacuum hose - What hose can i use to plug directly to the router and make my connection to the shop vac somewhere other than at the router? I was thinking of having the hose and wires bundled together so no reason to have a 1 1/2 hose if the router connection is only 1in.
Any other things I should consider or plan for while waiting for the kit?
