Hello,
Have put the thing together, made a basic frame, ran calibration on an older FW, running calibration on the 88 FW as we speak.
Figured a basic project that I want to build that requires nothing but a flat board with some holes in it.
Being completely unfamiliar with this machine except putting it together some months ago, I am wondering how it works with the placement of objects on the working surface.
I had the understanding that it might be beneficial to make the frame have a structure surrounding the workpiece with the same thickness as the workpiece, so there is a layer of OSB surrounding the designated workpiece area where I will be mainly cutting plywood.
My first concern is making the machine cut out the most optimal SQUARE area for the workpiece, the OSB surround is intentionally too big for this specific task because I wanted to be absolutely certain that the machine defines the most optimal surface area to work in.
Does this make sense?
How do I make the machine cut out the most optimal workspace by itself without messing it up by doing some rookie mistake?
Edit:
Also, the calibration process takes many hours, just like the first time with the previous FW, and the memory of the unit seems a bit limited, is there anything I can do to improve the process?
Would not mind going for an attempt to do some cuts at this point, but at this speed it seems I may not be able to complete the calibration today…
Edit:
Restarting the calibration process again, wishlist item:
Is there some way to avoid running the retract/extend cycle every single time?
Or is it enough to just make the belts extract a few cm?
The process is noticeably quicker to achieve some progress each time, but it seems I have to run this a few times to get started. Have made my first gcode file and made certain it is supposed to be centered, waiting for yet another calibration process to run its course.
Finally got up to 0.15 something where it seems to have stagnated completely.
Edit3:
… REALLY bad idea to extract the belts just a few cm befor running the process again. REALLY bad idea.
