I was trying to help a new Maslow owner, in Grand Junction Colorado set up his machine. He had the motors mounted 180 incorrectly, but even after fixing that, we ran into another issue. when feeding out the chains the left chain would feed out several feet correctly, but the right chain only fed out less than an inch. he is using a temporary sled right now, tring to get the final sled cut. He installed teamviewer.com so I could control his maslow remotely.
so I deleted groundcontrol.ini and started over. However when restarting calibration it seems like the software still has old data. for example the distance between motors was still saved after restarting the program. How does one totally erase the old settings to make sure we are working with a clean slate?
attached is the ground control ini file if that helps. If anyone lives near him, I know he would really appreciate some help. He wants to start making a sign business using the maslow and works from home due to disability.
groundcontrol ERIC.ini (1.5 KB)
