I’ll be assembling the Maslow kit soon and I’m not use about the router clamp. Obviously the router (any model) uses the base clamp to lock in place when in use. However, I with the Z Axes in place does the clamp need to unlocked or adjusted loose enough for the Z axes motor to move the router up and down freely?
The clamp should be closed, but loosened enough for the router to move
Thanks David. I thought the was the case but wanted to be sure.
-Rey
Don’t forget to use some lube so it can slide.
Dry Lube, Powdered Graphite…
A Grease Base Lube, I think would collect Fine Wood Dust and seize it up
I use bees wax.
Who would have thunk! ![]()
