Unable to save files in sketchup 2017 or 2018 using the flights addon. Is there another way? Flights ad on says unsigned in the manage ad on tab.
This recent thread talked about saving SVG files from Sketchup using one version of that extension. The extension is unsigned, but if you get the right version, it does work. Read the thread through and give that a try. Let us know how it works or if you need more help.
Worked ! Thanks so much!
Blurfl,
The method suggested to me worked for both sketches make version 2016 and 2017.
Stuart
