I’m having issues setting up my Maslow.
First of all the specs:
- MakerMade kit bought in May
- Running Mega
- Using an Rpi for WebControl version 0.933
- I uploaded the Holey Firmware from Webcontrol.
- Top Beam is 3700mm and is 500mm from the sheet (these are just quick estimates, I put the actual in the appropriate boxes in the setup).
I can connect to WebControl, the issues I’m having are as follows:
- Intermittent motor connection, sometimes when I hit test motors/encoders they work, sometimes not.
- If I try and follow the steps for setting a tooth to the top, at most I’ll be able to get one movement from the motors, but mostly nothing.
- Update in Help won’t work.
- Message: Unable to find valid machine position for chain lengths 160.37, 29.07 Left Chain Length Greater than System Settings Chain Length LeftChainLength: 3724.10 System Chain Length: 3360
Otherwise, here’s a portion of the log:
4.87: B05
4.89: Firmware Version 51.27
4.89: Ground Control Version 1.27
4.90: ok
4.90: Sent: G20
4.91: G20
4.92: ok
4.98: Sent: $$
5.02: $0=2450.00 (machine width, mm)
5.04: $1=1250.00000000 (machine height, mm)
5.05: $2=3722.60009765 (motor distance, mm)
5.07: $3=480.00000000 (motor height, mm)
5.08: $4=310.00000000 (sled width, mm)
5.09: $5=139.00000000 (sled height, mm)
5.11: $6=79.00000000 (sled cg, mm)
5.13: $7=2 (Kinematics Type 1=Quadrilateral, 2=Triangular)
5.14: $8=138.40000915 (rotation radius, mm)
5.16: $9=2000 (axis idle before detach, ms)
5.17: $10=3360 (full length of chain, mm)
5.19: $11=2000 (calibration chain length, mm)
5.20: $12=8113.72998046 (main steps per revolution)
5.22: $13=63.50000000 (distance / rotation, mm)
5.23: $15=800 (max feed, mm/min)
5.25: $16=1 (Auto Z Axis, 1 = Yes)
5.26: $17=0 (auto spindle enable 1=servo, 2=relay_h, 3=relay_l)
5.28: $18=12.60000038 (max z axis RPM)
5.29: $19=3.17000007 (z axis distance / rotation)
5.31: $20=7560.00000000 (z axis steps per revolution)
5.32: $21=1300.00000000 (main Kp Pos)
5.34: $22=0.00000000 (main Ki Pos)
5.35: $23=34.00000000 (main Kd Pos)
5.37: $24=1.00000000 (main Pos proportional weight)
5.38: $25=5.00000000 (main Kp Velocity)
5.40: $26=0.00000000 (main Ki Velocity)
5.41: $27=0.27999999 (main Kd Velocity)
5.43: $28=1.00000000 (main Velocity proportional weight)
5.44: $29=1300.00012207 (z axis Kp Pos)
5.46: $30=0.00000000 (z axis Ki Pos)
5.47: $31=34.00000000 (z axis Kd Pos)
5.48: $32=1.00000000 (z axis Pos proportional weight)
5.50: $33=5.00000000 (z axis Kp Velocity)
5.51: $34=0.00000000 (z axis Ki Velocity)
5.53: $35=0.27999999 (z axis Kd Velocity)
5.54: $36=1.00000000 (z axis Velocity proportional weight)
5.56: $37=33.00000000 (chain sag correction value)
5.57: $38=1 (chain over sprocket)
5.58: $39=3 (PWM frequency value 1=39,000Hz, 2=4,100Hz, 3=490Hz)
5.60: $40=0.00000000 (chain tolerance, left chain, mm)
5.61: $41=0.00000000 (chain tolerance, right chain, mm)
5.63: $42=2.00000000 (position error alarm limit, mm)
5.64: $43=0.00000000 (reserved1, deg)
5.66: $44=0.00000000 (reserved2, mm)
5.69: $45=0.00000517 (chain stretch factor, m/m/N)
5.71: $46=97.90000152 (Sled Weight, N)
5.72:
5.73: ok
5.73: Sent: $45=0.00000516850
5.87: Message: Unable to find valid machine position for chain lengths 160.36, 29.05 Left Chain Length Greater than System Settings Chain Length LeftChainLength: 3725.15 System Chain Length: 3360
5.88: ok
