I’m unable to get the sled to display/render in inkscape’s, or anything else that can print. It’s the only one of the design svg files that has this problem. Everything’s there, nicely done with circles instead of line segments, but a couple versions of Inkscape just don’t like it.
I wanted to make a quick copy of the permanent sled by printing the design, gluing it to some scrap plywood, and making it with conventional hand and power tools before doing a full recalibration. It’s probably something simple with the file but I’ve spent several unsuccessful hours. Any ideas, or is the file available in another format?
Inkscape takes a very long time to come up, but once up, the file opened correctly and quickly. Are there some Inkscape settings I could look up for you?
I’m not sure if this is the issue, but I ran into something similar when using a 3d service’s template. The solution for me was to change the View->Display Mode in Inkscape.
@Darryl, no different with toggle, no filters, or outline. I’m just about to try and print @blurfl 's PDF. I’m going to make it as designed, but am leaning towards converting into the pantograph version and hoping for a pleasant afternoon in the packed to the gills farm shop as it awaits all the woodworking tools moving to the other side of the wall.
@blurfl - that’s great, and the alignment grid was a really big help getting it lined up. I was doing cut and paste back when it involved scissors, real paste, and that white tape. While the alignment’s not 100% perfect this was way easier than the old days. Think the 3D printer glue stick will work to attach it.
Does anyone know what causes the SVG not rendering in inkscape?
I try to gain more insight in Ink-issues.
I just tried to open sled.svg and firefox also isn’t able to display the graphic
Edit
Inkscape exits with: Failed to load the requested file Sled.svg (the one currently on gitgub)
Firefox does not render the file. And displays the plain xml as text
I’m able to view the sled file in Chrome (and Firefox and whatever Windows browser is called now) but I can’t open it in InkScape either. I don’t get any errors, however, just a document with a selectable, but not viewable object. I downloaded the entire Mechanics-master as a zip file.
It does open in Illustrator, however. The only weird thing I see (in Illustrator) is that the stroke is set to “0”. You can view it in Outline mode.
I had to change the infill color of the big sled circle, then the mount holes became visible
One of the chain mount hole countersinks seems to be missing (the most upper left one)
Also Inkscape sees the file default setting as px. So the actual dimensions seem to be off when I change this to mm This seems to have 373 mm diameter. Or is that correct? I have 320 mm in my mind as being the diameter, not sure where i picked that up.
