No. I don’t know how to do that. Are there any instructions you can point me to?
The xy movement that I witnessed when I manually told it to move z by 1mm was
far too great to have been compensation for a change of 1mm to the XYZ
triangle. Is there a setting somewhere that would allow me to adjust the
level of compensation that xy makes to a z movement?
it just calculates the desired belt length based on the x/y/z triangle from the
anchor point.
If the Z was not all the way down when you did the calibration, or the Z stop
value is not corred (or was not correct when you did the calibration), then the
anchor locations that were calculated are not correct and you will have errors
I have not been able to complete a calibration in a long time. It takes a long while but inevitably ends with WARNING FITNESS TOO LOW. DO NOT USE THESE CALIBRATION VALUES!
I think you may need to troubleshoot this more. what is the fitness that it
calculates? (the default cutoff was 0.5, I think bar lowered it to 0.45)
If your anchors move, if the Z offset values in the config don’t match the
reality of your machine, if the belts aren’t tight as you calibrate, those could
all result in bad anchor coordinates (i.e. a bad calibration)
you may also want to do a manual calibration check and see how close the result
is to what the auto calculated one gives you.
some people have had better results with the manual version, but it depends
HEAVILY on how accurate your measurements are.
[MSG:INFO: Top Left pulled tight with offset -0.032]
[MSG:INFO: Bottom Right pulled tight with offset -0.021]
[MSG:INFO: Bottom Left pulled tight with offset -0.043]
[MSG:INFO: Top Right pulled tight with offset -0.032]
[MSG:INFO: Top Right pulled tight with offset 0.064]
[MSG:INFO: Top Left pulled tight with offset 0.032]
[MSG:INFO: Bottom Left pulled tight with offset 0.043]
[MSG:INFO: Bottom Right pulled tight with offset 0.000]
What does that tell you?
that looks good. If the numbers were larger, that would indicate a problem. It
doesn’t hurt to do it a few more times.
They each get tight and they are not getting caught on anything.
It is not a standard frame, but I don’t detect flexing. Two of its corners are on hinges connected to my shed. The plywood is screwed to the two center beams to minimize diagonal flexing.
setup a tripod on each corner and take a video of the corner anchor at close
range, then play back on fast forward to see if it moves.
Is there any possibility that a recent firmware update is causing z movement to unduly move x and y, causing this issue?
I understand that you believe that frame flex is likely the cause of my failure to complete a calibration. I will be able to test that this weekend, when a regular Maslow frame will become available for me to test it on.
What is the most likely cause of my now-consistent 15mm error problem? I send it the job, it starts pocketing and consistently fails on the third pocket with this:
[MSG:WARN: Position error on Top Left axis exceeded 15mm while running. Error is 15.012mm Counter: 1]
[MSG:WARN: Previous error was 15.012mm]
[MSG:WARN: Position error on Top Left axis exceeded 15mm while running. Error is 15.048mm Counter: 2]
[MSG:WARN: Previous error was 15.048mm]
[MSG:WARN: Position error on Top Left axis exceeded 15mm while running. Error is 15.084mm Counter: 3]
[MSG:WARN: Previous error was 15.084mm]
[MSG:WARN: Position error on Top Left axis exceeded 15mm while running. Error is 15.111mm Counter: 4]
[MSG:WARN: Previous error was 15.111mm]
[MSG:WARN: Position error on Top Left axis exceeded 15mm while running. Error is 15.138mm Counter: 5]
[MSG:WARN: Previous error was 15.138mm]
[MSG:WARN: Position error on Top Left axis exceeded 15mm while running. Error is 15.166mm Counter: 6]
[MSG:WARN: Previous error was 15.166mm]
The 15mm error is caused by a connection issue between the encoder and the main controller board. The hot glue can help, but the real solution is the new encoder cables that we are working on.
Just curious as to what conductors are being used in the Cat 5 cable from board to encoder? Would it be possible to hardwire (solder) one end ? Most likely for me would be the encoder board side. Just a thought.
This might be an opportunity for improvement. Im thinking sort of like calibration utility but instead for magnet check / frame flex utility tool to help determine this ?
Under “Config” there is the “Test” command. That won’t check it the magnet is slipping, but it will check whether or not the magnet is being detected in general.
@bar did make a version at one point that would test for fame flex.
to test for frame flex, you pull lightly to tighten the belt, then you apply
more force and see how much the belt lengths change.
for magnet slippage, you need to extend the belts and then retract them to a
known physical point. so the normal extend/retract cycle will show this.
