It’s all good, I managed to put it back and it’s working.
Going to try and get some time in the next couple of weeks to put the frame together and get the sled cut
good day! Do you use a mill less than 6mm? I want to install a 3.175mm milling cutter in a bosch 1200 router, but I can’t find the right collet. what collet do you use for the bosch router?
You are looking for a 1/8 inch collet? Metric and imperial available for Bosch.
I would need to digg where I sourced them almost 2 years back, but the part number on the pic could help find them.
Edit: Sorry for the confusion. I went to the workshop to check and the smallest metric is 6mm and imperial 1/4 " ~ 6.35mm
Reducers will work, but stated as ‘not recommended’ for long runs in several cnc forums. This recommendation might not apply to the Maslow because of our low feedrate and lower router speed.
Edit: What collets do you have? A 1/4 to 1/8 reducer like this might be what you are looking for:
However if you can find one with 8 ‘grooves’ instead of 1, like this
I would more trust in it and pay a possible + price difference.
FYI: The concerns in the cnc-forums regarding reducers are that they can introduce an ‘off-centre’ placing of the bit resulting in additional wear on the first bearing in your router from the bit side. Taking your collet apart and cleaning it with every tool change reduces that risk to a good extent. A ‘8-grooved one’ if you can find it help also, plus ‘fine-feeling’ in your fingertips while inserting the bit and tightening.
Edit2 links: This has at least 3 grooves:
https://www.amazon.com/Engraving-Router-Adapter-Convert-Machine/dp/B00NL7ZQCQ
This looks interesting as thinner bits are also usually shorter:
I’ve been looking into it, but haven’t found a good solution yet.
I have just ordered a 1/4" collet extension, and two 1/8" cutters with 1/4" shanks from Banggood. We’ll see how we get on once they arrive.
I’ve converted to spindle but would you consider to post links to the items you bought (might help others)?
Good point.
Previously I have bought a long bit from them, 3/8" diameter cutter with 1/4" shaft. It has arrived, but I haven’t tried it. As you know, the router is a lot farther from the material because of the sled, so a longer bit is required, or a bit extension.
That would solve 2 problems i’m having at the same time. Smaller end mills, and my z -axis bottoming out all the time.
I’m ordering some as well, i don’t see why it won’t work.
Ok. Let’s see how long they take to arrive. Me in New Zealand and you in Europe (?). I ordered mine yesterday. Go!
Hi there!
I received my Bosch kit and assembled it without problems (just had to widen the holes for the bolts with a 5mm drill). But now before starting the first job for my Maslow, I found one of the five distance wood layers, I obviously forgot to glue in.
Actually the metal junction thing, holding the motor shaft and threaded rod together - seems to be in there without being pushed together too much.
Should I be worried though? Thanks guys
It looks like you’ll be fine. just make sure the coupler rests on the part that touches the router.
The bolts do wear out and come loose after a while though. That’s why i made the holes a bit too small, that way the bolts are as tight as possible. I found out this weekend that i lost 3 of the 4 bolts holding the motor in place, so it might be a good idea to keep an eye on that.
Hi all, so so close to getting going and thought i was there but it seems like there is some kind of lock preventing the router to plunge. Have attached a photo.
Followed all the instructions but when I tried adjusting the height the assembly popped out, so have opened it up again and it is solid, might I have jammed it somehow? If so any ideas on how to fit it?
Thanks
Hi managed to loosen it using a hammer. I can’t work out how the motor is supposed to adjust the height following these instructions.
Could someone help please?
Thanks
Hi! Great project! Could you explain better how the lead screw is connected to the body of the router? I saw how it is connected to the motor and to the nut but I don’t understand if it is connected somehow to the base of the router.
The nut is connected to the router, and when you lower the motor it compresses the spring in the router and that keeps the motor mount in place. the 2 allen key bolts fit into the holes of the router and keep it form turning. If you were to raise your z-axis too high, the motor mount would just lift up.
I just noticed your year old picture, but you might want to remove that yellow ziptie. Interference from the power cord has been known to move the Z-axis.
Also, i’m sold out and i’m not getting new stock. If anyone wants to take over, feel free to do so.
Hi, I don’t understand how the nut is fixed to the body of the router. It seem only inserted. Maybe you could provide a dedicated photo in order ti help me to understand how it fit.
The nut is connected to the shaft that connects to the base plate. The motor is connected to the housing. The motor pulls the two together and the spring pushes them back up when the motor raises.
