That sounds very frustrating!
âConnection timed outâ signals a problem with the USB connection. Here are some things to try:
- Are the ends securely plugged in? (donât forget the USB extendsion cable connector)
- Is it better without the USB extender cable? (this can be troublesome to test, but informative)
- Is there a different USB connector on the computer to try?
- Make sure that the Arduino IDE program isnât running, it can âstealâ the USB portâŚ
If these things donât help, tell us about the computer and the operating system youâre using. Letâs get you up and running!
Which port is the power plugged into? The Shield or the Arduino? Do you have another USB cable you can try?
You want the power plugged into the Shield.
So hereâs the deal. I was able to get the right motor to turn as z-axis, so I know it works at least. I tried a different USB cable and every USB port on the laptop. I also have the power plug into the motor shield. Ground control only seems to have an issue when it test the left motor and then tries to test the right motor then I get the âconnection timed outâ error.
Laptop is an HP that I use at work.
I also have a dell laptop Iâm using too, but having the same issues.
Quite probably unrelated, but I was suffering repeated Connection Timed Out issues after the latest update to firmware and GC. I ended up redownloading, reinstalling and that resolved the issue.
Try loading the blink sketch to the Arduino then Uploading the firmware again.
I uploaded the Blink software and got the blinking amber light as expected. I then uploaded the firmware and continue to get the same âconnection timed outâ error. I am using v1.06 of the firmware and GC.
Please try 1.04 -
Let us know if you see the same connection issue
Do you have any previous experience with Arduino?
I did a fresh download and install of firmware v1.06. Same issue. I tried it with v1.04. Same issue.
I have no experience with Arduino, this is my first one. Sorry, but you guys have another noob on your hands.
Just so I understand, if you run GroundControl, and without clicking anything you just watch, does it get to âconnected on port COM3 ⌠readyâ and stay that way, without the âconnection timed outâ error? Or does the timeout message pop up even if youâve not done anything?
Windows folks, how does GC behave with the wrong version of pyserial? Maybe thatâs not an issue with the Windows GC package?
This is the Windows portable package. It has everything rolled into it. I will try to find a good Arduino demo with a serial console output. This would be a way to test the serial connection. I will a wait answer to âif you run GroundControl, and without clicking anything you just watch, does it get to âconnected on port COM3 ⌠readyâ and stay that way, without the âconnection timed outâ error? Or does the timeout message pop up even if youâve not done anything?â
How connected to the motor rotating is the issue? Does it stay connected as long as you donât try to make the motor turn? Could we be seeing an issue with the board or the Arduino itself? Weâre more than happy to send you new ones if that seems like a possibility.
Sorry for the trouble!
Oh, It stayed connected this time after the âconnection timed outâ but often I have to unplug the USB and plug it back in or manually reconnected through actions, connect.
This is for the Arduino uno R3. It is applicable to other Arduinos. Where are you located?
Here is article on the serial Monitor -
There is a program under Examples - Basics -> ReadAnalogVoltage
It should output to the serial monitor.
I think there is a chance that something is wrong with one of the motor driver chips. It seems like a long shot but thatâs the only thing I can think that would describe this behavior.
If one of the chips was faulty internally it could be shorting or doing something strange when you command the motors to turn which would trip the Arduinoâs internal circuit breakers and drop the connection.
Its a long shot, but I think itâs worth investigating. If you send your address to info@maslowcnc.com weâll send you a new shield and Arduino so we can eliminate that possibility
I followed the instructions, on both laptops, for the loop back test and got this. I could not read anything and it scrolled so fast even after I turned autoscroll off I really couldnât make heads or tails of anything.
One more thing, I had TX0 and RX0 jumpered and ran the serial monitor. But, I also pressed reset and held it as well. This stopped the scrolling and allowed me to type commands which was echoed on the serial monitor screen. As soon as I released the reset button it resumed to scroll manically and would not allow me to type any commands.
