This is probably caused by user error but I could not fix it.
TL;DR: Used wrong version of GroundControl with firmware, things got messed up, Weird G2/G3 cuts, don’t know how to fix. Tried re-flashing firmware.
I recently upgraded to firmware 1.2.4 and upgraded to same GroundControl version on laptop 1. Days later I grabbed the wrong laptop that had older GroundControl 1.2.1 and tried to use it. Immediately asked the sled to move to Home position and got the “wrong version error” and another error “Unable to find valid position for chain length”. Quit out of GroundControl.
Since the machine is at remote location, poor internet, I decided to downgrade firmware since I had 1.2.1 on the laptop. That did not work as version number remained 1.2.4. So downloaded firmware and groundcontrol 1.2.4, flashed the mega, and launched ground control.
Still had the “Unable to find valid position for chain length” error so did the automatic chain length calibration, resetting sprocket position and having the chains feed out. Moved the sled to work area extents to validate calibration settings were correct. Checked previous calibration settings. Everything looked good.
Start cutting and on first pocket cut < 1/4" depth get “Sled cannot keep up error”. Search for problem and see reference to Advanced settings -> Position Error Limit which I could have sworn was 20 and is now 2. See other issue that mentions upping it to 120. Latest firmware Sled not keeping up error. Set it at 20 with same result. Set it at 40 at which point it works.
Start cutting and go through about 4 different operations (drill, pocket, bore, outline pocket) which have no problem. Then get to outline cut for the exterior of the piece and G2/G3 cuts go horribly wrong. See image:
So the deep vertical cut (most right) goes down, and does “G3 X-9.9375 Y-7.4219 I0.125 J0” which cuts correct, then quick G1 straight cut to “G2 X-8.0625 Y-7.7969 I0 J-0.375” which messes up completely. Then does another straight cut followed by “G2 X-8.1875 Y-11.6719 I-0.125 J0” which does similar Z cut but to a lesser extent.
This is not error in sled movement due to friction, chain sag, uneven ring movement. The sled purposefully moves in this weird ‘Z’ cut instead of doing a smooth arc. Watched the chain movement and have video showing this but could not figure out how to upload it. If you have any insight on uploading images, video, code to this site please let me know as I have no idea how to do this.
Gcode looks correct, in text, GroundControl and ncviewer.
So I exit out of GroundControl and re flash 1.2.4 firmware noting success message and reboot. Do power cycle to make sure. Restart GroundControl and attempt cutting again and see the same thing happen.
Any ideas of what has happened and how I can fix it?
Using default frame, default sled with ring, with default Ridgid router with z-axis, but slightly different weights (2x5 Lbs divers weights) which worked well before.
Offending Gcode: (Multi depth, max 1/4" per depth cut, with tabs)
(2D CONTOUR EXTERIOR)
G0 Z0.2894
G0 X-44.2124 Y12.6531
G1 Z-0.225 F13.1
G1 Y12.6528 Z-0.2289
G1 Y12.6519 Z-0.2327
G1 Y12.6504 Z-0.2363
G1 Y12.6483 Z-0.2397
G1 Y12.6458 Z-0.2427
G1 Y12.6428 Z-0.2452
G1 Y12.6395 Z-0.2473
G1 Y12.6358 Z-0.2488
G1 Y12.632 Z-0.2497
G1 Y12.6281 Z-0.25
G1 Y12.6031 F40.
G3 X-44.1874 Y12.5781 I0.025 J0
G1 X-8.1875
G2 X-8.0625 Y12.4531 I0 J-0.125
G1 Y8.7031
G2 X-8.4375 Y8.3281 I-0.375 J0
G1 X-9.9375
G3 X-10.0259 Y8.2915 I0 J-0.125
G3 X-10.0625 Y8.2031 I0.0884 J-0.0884
G1 Y-7.2969
G1 X-8.4375
G1 Y-11.5469
G1 X-44.1874
G2 X-44.3124 Y-11.5469 I0 J0.125
G1 Y12.4531
G2 X-44.1874 Y12.5781 I0.125 J0
G3 X-44.1624 Y12.6031 I0 J0.025
G1 Y12.6281
G1 Y12.632 Z-0.2497
G1 Y12.6531 Z-0.225
G0 Z0.125
G0 X-44.2124
G1 Z0.0394 F13.1
G1 Z-0.475
G1 Y12.6528 Z-0.4789
G1 Y12.6519 Z-0.4827
G1 Y12.6504 Z-0.4863
G1 Y12.6483 Z-0.4897
G1 Y12.6458 Z-0.4927
G1 Y12.6428 Z-0.4952
G1 Y12.6395 Z-0.4973
G1 Y12.6358 Z-0.4988
G1 Y12.632 Z-0.4997
G1 Y12.6281 Z-0.5
G1 Y12.6031 F40.
G1 X-8.1875
G1 Y8.7031
G1 X-9.9375
G1 Y-7.2969
G1 X-8.4375
G1 Y-11.5469
G1 X-44.1874
G1 Y12.4531
G1 Y12.6281
G1 Y12.632 Z-0.4997
G1 Y12.6531 Z-0.475
G0 Z0.125
G0 X-44.2124
G1 Z-0.2106 F13.1
G1 Z-0.725
G1 Y12.6528 Z-0.7289
G1 Y12.6519 Z-0.7327
G1 Y12.6504 Z-0.7363
G1 Y12.6483 Z-0.7397
G1 Y12.6458 Z-0.7427
G1 Y12.6428 Z-0.7452
G1 Y12.6395 Z-0.7473
G1 Y12.6358 Z-0.7488
G1 Y12.632 Z-0.7497
G1 Y12.6281 Z-0.75
G1 Y12.6031 F40.
G1 X-41.4874
G1 X-41.4374 F10.
G1 Z-0.625 F40.
G1 X-40.9374
G1 Z-0.75 F13.1
G1 X-35.4875 F40.
G1 X-35.4375 F10.
G1 Z-0.625 F40.
G1 X-34.9375
G1 Z-0.75 F13.1
G1 X-29.4875 F40.
G1 X-29.4375 F10.
G1 Z-0.625 F40.
G1 X-28.9375
G1 Z-0.75 F13.1
G1 X-23.4875 F40.
G1 X-23.4375 F10.
G1 Z-0.625 F40.
G1 X-22.9375
G1 Z-0.75 F13.1
G1 X-17.4875 F40.
G1 X-17.4375 F10.
G1 Z-0.625 F40.
G1 X-16.9375
G1 Z-0.75 F13.1
G1 X-11.4875 F40.
G1 X-11.4375 F10.
G1 Z-0.625 F40.
G1 X-10.9375
G1 Z-0.75 F13.1
G1 X-8.1875 F40.
G1 Y8.7031
G1 X-9.9375
G1 Y4.6281
G1 Y4.5781 F10.
G1 Z-0.625 F40.
G1 Y4.0781
G1 Z-0.75 F13.1
G1 Y-3.1219 F40.
G1 Y-3.1719 F10.
G1 Z-0.625 F40.
G1 Y-3.6719
G1 Z-0.75 F13.1
G1 Y-7.2969 F40.
G1 X-8.4375
G1 Y-11.5469
G1 X-10.8875
G1 X-10.9375 F10.
G1 Z-0.625 F40.
G1 X-11.4375
G1 Z-0.75 F13.1
G1 X-16.8875 F40.
G1 X-16.9375 F10.
G1 Z-0.625 F40.
G1 X-17.4375
G1 Z-0.75 F13.1
G1 X-22.8875 F40.
G1 X-22.9375 F10.
G1 Z-0.625 F40.
G1 X-23.4375
G1 Z-0.75 F13.1
G1 X-28.8875 F40.
G1 X-28.9375 F10.
G1 Z-0.625 F40.
G1 X-29.4375
G1 Z-0.75 F13.1
G1 X-34.8875 F40.
G1 X-34.9375 F10.
G1 Z-0.625 F40.
G1 X-35.4375
G1 Z-0.75 F13.1
G1 X-40.8874 F40.
G1 X-40.9374 F10.
G1 Z-0.625 F40.
G1 X-41.4374
G1 Z-0.75 F13.1
G1 X-44.1874 F40.
G1 Y-8.8469
G1 Y-8.7969 F10.
G1 Z-0.625 F40.
G1 Y-8.2969
G1 Z-0.75 F13.1
G1 Y-2.8469 F40.
G1 Y-2.7969 F10.
G1 Z-0.625 F40.
G1 Y-2.2969
G1 Z-0.75 F13.1
G1 Y3.1531 F40.
G1 Y3.2031 F10.
G1 Z-0.625 F40.
G1 Y3.7031
G1 Z-0.75 F13.1
G1 Y9.1531 F40.
G1 Y9.2031 F10.
G1 Z-0.625 F40.
G1 Y9.7031
G1 Z-0.75 F13.1
G1 Y12.4531 F40.
G1 Y12.6281
G1 Y12.632 Z-0.7497
G1 Y12.6531 Z-0.725
G0 Z0.25
GroundControl.ini (using 1.2.4)
[Computed Settings]
distperrot = 63.5
kpposmain = 1300
kiposmain = 0
kdposmain = 34
propweightmain = 1
kpposz = 1300
kiposz = 0
kdposz = 34
propweightz = 1
distperrotrightchaintolerance = 63.50000
kpvmain = 5
kivmain = 0
kdvmain = 0.28
kpvz = 5
kivz = 0
kdvz = 0.28
chainoversprocketcomputed = 2
fpwmcomputed = 3
kinematicstypecomputed = 2
distperrotleftchaintolerance = 63.50000
[Maslow Settings]
bedheight = 1219.2
motoroffsety = 425.1
sledwidth = 310
zaxissafeheight = 5
bufferon = 0
bedwidth = 2438.4
comport = /dev/ttyACM1
macro1_title = Macro 1
sledheight = 139
macro2 =
macro1 =
zaxis = 1
sledcg = 79
macro2_title = Macro 2
colorscheme = Light
zdistperrot = 3.17
motorspacingx = 2993.81
[Advanced Settings]
rotationradius = 119.0
chainextendlength = 1650
kiv = 0
gearteeth = 10
spindleautomate = None
kdvz = 0.28
chainsagcorrection = 34.351644
chainpitch = 6.35
chainlength = 3360
propweightz = 1
zencodersteps = 7560.0
maxfeedrate = 800
enablepospidvalues = 0
rightchaintolerance = 0
enablevpidvalues = 0
maxtouchprobeplungedistance = 0.0
kpvz = 5
kdposz = 34
chainoversprocket = Bottom
kpposz = 1300
fpwm = 490Hz
kdpos = 34
encodersteps = 8113.73
truncate = 0
homex = 0.0
homey = 0.0
kinematicstype = Triangular
kipos = 0
kdv = 0.28
kiposz = 0
digits = 4
kppos = 1300
kpv = 5
propweight = 1
positionerrorlimit = 2.0
kivz = 0
leftchaintolerance = 0
[Ground Control Settings]
zoomout = pagedown
centercanvasonresize = 0
viewscale = .45
zoomin = pageup
validextensions = .nc, .ngc, .text, .gcode
[Background Settings]
backgroundfile =
manualreg = []
Using 3D models made in Rhinoceros v5, exported as IGES to Fusion 360, using MaslowCNC Post Processor to generate G-code, all of which previously worked well (except for teething problems I have already worked out). Tool feed rate is 1200mm/m from Fusion 360 recommended which I think is reduced to max Maslow rate 1000 (maybe 800) mm/m.
